crossover w/o the arm? aka y link
I think this is urban legend. It has already been proven that you can do hydraulic assist with stock push-pull steering. The key is that you have a hydraulic steering gear and a hydraulic assist ram. The fluid is shared between them. The factory power steering is a mix of hydraulic and mechanical steering to begin with.
Just because someone has done it and hasn't ripped the steering box from the frame doesn't mean it won't happen ;)
And just because fluid is shared between the two does not mean they work together.
The valve in the steering box will be supplying full pressure/flow to the ram when its cranked all the way, if the draglink wasn't there it wouldn't bind. The ram would be all the way one way and the pitman arm would be all the way one way.
Add in the draglink, which is a mechanical connection between a fixed reference (the frame/steering box) and a moving object (the axle), and things bind.
The hydraulic ram doesn't care what the frame or axle are doing, when you turn the wheel left the valve routes fluid to the ram and it puts pressure on the axle to turn left.
The mechanical setup isn't that way (and it is a hydraulically assisted mechanical setup). You can have the steering wheel turned all the way but the tires aren't necessarily doing the same thing.
This is why it binds.
Again, I'm sure people have tried this and not seen bad effects (yet anyway) and that's because the springs and spring bushings have some give. Eventually it will catch up, the shorter the draglink is the more it clashes with a hydraulic ram.
This might be an easier way to think about it, hook up just the ram (leave the draglink off) and flex the truck out. Crank the wheel all the way one way and let me know how close you would be to being able to hook up the draglink (its not going to be close ;))
What are the tie rods tapered for. Chevy, Ford? Any part numbers handy?
hmm, ill have to see if I have the receipt. The tre has to be reamed out for the correct taper after you buy it btw. WFO sells this too, call trevor up, he rocks.
