Crush sleeve eliminator
Jason4x4
Chandler, AZ
Anyone make something like this for GM axles??
Solid Spacers
Solid pinion spacers replace the factory crush sleeve. These spacers reduce the need to retighten pinion nuts and reduce R&P failure due to excess backlash
Very interestion. Would like to find out more info on those.
Well i hate crush sleeves so when i go to install my 1410 yoke on my 14ff i'm going to make a solid spacer and buy a shim pack.
I hear ya on crushing sleeves , when we did the 4.56 , I actually had to use a breaker bar , with my jack handle slid over it , and stand on the damn thing . Haven't gotten the feel for starting it crushing with an impact like some others can do .
We went a little at a time and checked the preload . Luckily it got done right , its quiet and over the 10,000 mile mark now .
When we did my 14ff we shattered the 3 or 4 inch think cheap casy block that came with my buds 40 ton A frame HF press. It was LOUD and scary :eek1:. I had a 3 inch block of 1018 steel, it did the trick. Crush sleeve's SUCK period. This solid spacer is a great idea IMHO.
My 40 ton air over hydraulic press works great for getting them to start to crush. :D
Bringing this back up.
Has any one tried it yet.
Was gonna replace my yoke with flange and might try it.
Well, there's not really any experimentation here. ~1/2 of all diffs use shims instead of crush sleeves anyway (~90% of Dana diffs), shims/spacers are better. Crush sleeves make assembly quicker/easier in the factory.
If you switch to a spacer/shims, you'll still need to pull everything apart and set the pinion bearing preload.
Big block and 44 boggers will break those 12 bolts.They've broken a 14 bolt twice and a Dana 60 three times for me.
