Crush sleeve won't crush
broc944
Northern Minnesota
I am setting up my gears in my 14bff, following these directions
http://www.pirate4x4.com/articles/tech/billavista/PR-ARB/articles/14b_Gear_Setup
Put 12 tons on it and the crush sleeve will not crush, ever thing else has gone perfect, I was using a pipe nipple over the pinion, and it started to give, so I stopped, going to walk away from it for the time being, I guess I will try using a piece of pipe next, which should not give, but still I wonder if my 12 ton shop press will be enough. Any ideas on what I am doing wrong? I have done this once before, many years ago, and I do not remember having this problem with the crush sleeve. Thanks in advice for any words of wisdom.
i just did the gears in my 14bff last weekend, i put the whole pinion assembly together then put the yoke on and put it in a press, not sure how big the press was, it took alot of pressure to crush it, i had a cheater bar on the press too
It usually takes on average about 10 tons to get them to start to crush, after that they crush FAST.
I just tried it again, nothing. When I get home from work I will try the cheater on the press handle, but I laid into it and it did not budge. I think maybe my press may have been over rated on its capabilities and that it is not 12 tons.
I used a 20-ton press, but had to use a cheater bar, and it felt as though we were close to maxing out the press, but it definitely crushed.
I would be stay away from a press if possible due to the fact that if it aint perfect your bearing preload will not be correct and not last long. what I always do is make a yoke holder or use a big pipe wrench with a piece of pipe on the end to hold it against the ground, frame, etc. take a long breaker bar with cheater pipe on it and put it at the highest point possible and have someone stand on the pipe from outside the vehicle. Have never had one that would not crush this way and no chances of over doing it if careful.
How is the pinion sitting in the press???
I made a bushing so I can press directly on the bearing inter-race.
Basically what I did, except I had the vehicle on a hoist. It took two of us to turn the cheater bar to get it to start crushing.
just be careful when pressing stuff like that. working in machine shops for so many years you get to see some dangerous stuff happen. I have seen heat treated steel blocks explode and send shrapnal 50 feet across the shop, and imbed into walls. it does sound like a shot gun going off. even aluminum will snap and send shrapnal flying. if you get hit in the eye, its gone for sure.
I think our press at work is 20 ton, and they crush with a little resistance, but no cheater bar needed. Just take it to a shop and ask them to do it.
Tonight I finally crushed the focker:D , bought yet another press, 20 ton, took everything it had along with a persuader, I definitely was standing off to the side with my cool safety glasses on just in case something slipped. Went ahead with setting the preload which went perfectly.
One safety related note that I noticed that has not been mentioned in any of the posts I have read, and that I just experienced, shims are very sharp:doah:, do not attempt to use your thumbs to align them, bad things will happen, amazing how much blood can keep dripping out of the cuts in a persons thumbs.:eek1: :eek1:
I just want to formally thank the brotherhood with the assistance I was given, I plan on swapping the axle in this Saturday.
I am not sure i fully understand. When i set up my stock 10 bolt (not sure if there is any diference) I just used my 3/4 inch air gun, And it crushed fine.
Yes, they can be a PITA http://coloradok5.com/forums/showthread.php?t=166206
A 14FF crush sleeve is much stouter than a 10 bolt sleeve . The 14 bolt sleeve strats to crush at around 360 ft. lbs. of torque so it is common to use a press to get things moving to where the air gun is an option once more.
Tom
Oh, The 3/4 inch air gun i used is rated at 550 FT. lbs
550 lb-ft on an impact gun isn't the same as 550 lb-ft of continuous load. I daresay that even a 1" drive gun would have a hard time with a 14bff crush sleeve.
And besides that, not everybody has a 3/4" drive air gun.
It's not that common of a tool for the back yard do-it-yourselfer.
IN his defense we sometimes crush them with 1/2" guns at work, its not THAT hard.
