CUCV 60's/14 bolt's
1-tonmudder
In a junkyard somewhere
Everybody know's about these.$1700 a set Located in Greeneville,Tn and can be picked up there.
I will be parting both trucks.
I'm looking for the two brackets that bolt to the inside of the framerails from top to bottom, just aft of the motor mounts.
Jeff
do you still have that D60? If so do you know what gear ratio it has? thanks, josh
No,at some point both trucks have been moved with a forklift,and both rear shafts were bent.That's a pisser since I could have sold them 10 times.:mad:
