CUCV Blazer
FSJeeper
Texas
I just picked up my CUCV Blazer. I am putting my M715 project to the side to get this one done. I have a set of excellent condition M1028 CUCV axles to go in it. 4.56 gears, detroit rear, powerlock front, Dana 60/14 bolt.
I have a 6.2 built up already. I will be putting a web page toegether to detail the buildup. I do not think more can be done to a 6.2. Should do 300HP/500 FTLBS at about 1900 rpm.
I am going to run an eaton 30% gear splitter/OD and NP205 when I get the time to do the install. In the meantime, I am going to run the stock T400/NP208.
The CUCV is very low mileage and I will have a nice set of 10 bolts to sell or trade. I need a tailgate, all of the pedal assembly, steering column, etc. to convert this to a standard, and some other stuff.
Thanks for such a great site!
sounds like a nice project. If i am ever in houston i will let you know and maybe i can stop by and give you a hand with something. i may be interested in those 10 bolts when they become available. what gears do they have? let me know and I could come get them!
Justin
Austin, Texas K5'er
Thanks
The 10 bolts are 3.07 geared, front open, rear Gov Lock. Low mileage.
What's an Eaton 30% gear splitter/OD ??
I may be able to help you out on the manual conversion parts. Send me a PM if you're interested.
<a target="_blank" href=http://coloradok5.com/gallery/75K5>http://coloradok5.com/gallery/75K5</a>
The Eaton unit is an axuillary transmission that mounts between the bellhousing and transmission. Like a AA Ranger OD/gear splitter unit but a lot heavier duty for big trucks. It is 30% for OD or splitting gears. The trans is a NP435 with NP205 tcase.
I'm not sure, so I thought I'd ask... What is a CUCV Blazer? Is it a surplus military blazer?
If you knew the truth, you too would be against marijuana prohibition!
Blue '74Blazer Topless W/ 35 BFG Muds1" Body Lift W/ Energy Susp. Bushings
<a target="_blank" href=http://www.geocities.com/MotorCity/Highway/3969/cucvpage.htm>http://www.geocities.com/MotorCity/Highway/3969/cucvpage.htm</a>
Austin, Texas K5'er
What part of houston do you live in i live in tomball it is outside of houston
"When you say i drive a fullsize are you calling my wife fat."
J/K i was bored and made that up i don't even have a wife i'am only 17.
