I'm getting my m1009 on the road soon (went around the block yesterday
) after about a year of toil and frustration. Can someone post a pic of your v-belt set up so I can figure out which v to use for my hydro pump? My pump (non cucv) has provisions for two belts. I can use the smaller crank v closest to the block or the larger one in the second position. I would assume that the larger one would spin the pump faster, but I don't know if that a good thing or not.
Thanks.
) after about a year of toil and frustration. Can someone post a pic of your v-belt set up so I can figure out which v to use for my hydro pump? My pump (non cucv) has provisions for two belts. I can use the smaller crank v closest to the block or the larger one in the second position. I would assume that the larger one would spin the pump faster, but I don't know if that a good thing or not.Thanks.
