Cummins conversion
Torogrande79
Registered Member
Alberta
Ok guys, I know were all Chevy men, I hope were also openminded enough to accept that a Cummins in a classic Chevy isn't such a bad thing either. I was watching the Cummins conversion they did on Trucks on the powerblock, using the Clubcab long box dodge diesel , and dropping a crewcab short box ford body onto it. I'd like to to try the same thing but using a Chevy body . Anybody have any ideas of what body style might work? just fishing right now, any ideas would be greatly appreciated... just dont shoot me for asking . I happen to have a clubcab dodge 2500 diesel shortbox sitting out in my back yard right now. would like to keep the drivetrain and everything on it, and drop a classic chev body onto it somehow, if possible . the wheel base is 138.7". Thanks again for any info
Think it would be easier just to swap the drivetrain to your truck than swap the body...
that's what I figured to . Like I said, I saw it done with a ford, was just curious about doing it with a chev body.
If I had their tools/garage/budget, probly do it that way too. They make everything look easy...dirty bastages.....
what year and wheel base of chevy truck ? is it for wheelen , tow rig ?what year is the dodge truck ?
thanks for the input guys. I figured it would be a job and a half , I guess more or less I was just curious if it could be done. And to answer the above question the truck is a 99 24 valve with a 5speed clubcab shortbox . And I'm in the lethbridge area in southern alberta. The engine is for sale if you know anybody in alberta looking . It can be heard running.
A 12 valve cummins is a lot less work for swapping ,the sick is simple too, but that year of dodge has a left hand side diff . You could put in a ford axle and run all dodge stuff . The 24 valve swap will need the factory dodge ECM for the engine .
