OK so if all works out, I'll be picking up a 92 Dodge 250 2wd cummins truck for daily/tow duties. Today I picked up a GM NV4500 out of a 2wd pickup cause it was CHEAP!
1) I know I'll need a different Bell housing. Will any 4bt/6bt one work? or do I need one correct for that generation truck?
2) I'm hearing different things about input shafts. Does this have to be changed from the GM one?
3) The 5th gear..... On the ground, this one works. Is there any "simple way" to check this for certain without complete disassembly? Should I be pulling it apart to update whatever it is that they do?
4) What else should I know about this trans itself and the swap?
But wont know for sure till I get back to my storage to have a better look. If thats's the case, I can't use it on a cummins? Or does it requre a aftermarket bell?
