cummins ? ok here???
Blazin'4x4
Colorado
Just need to know at what temp does my cooling fan turn on.
She overheated pulling 3000lbs:mad:
Tryin to diagnose a thermostat or fan problem.
1998 dodge 2500 with 24 valve cummins.
viscouse fan clutch, maybe not locking up at all anymore. maybe rad is dirty/ maybe stat stuck. you can get various temps on the stats, pull it and look at it to know for sure.
test the stat in a pot of water on the stove. put a thermometer in the water. turn on stove. view the temp that it actually opens at. maybe need a cooling system acid flush and a rad cleaning.
