apache
Id do some seroius checking into potential emissions testing to come down the pipe not that the green/dems are in control again. Here in Ca theres been talk of smog check for diesel pickups,working in the Gov end of things agencies are being forced to get rid of diesel equiptment that will not be able to pass up comming regs or current regs and are to pricy to convert to electronic. Two of them were NTA 855 Cummins powered rigs. Otherwise id go with a pre 98.5 12 valve engine. Just look for KDP damage if its a junkyard special. Do a search on Killer dowell pin and read up before you lay down any hard earned coin. Ive had 3 of them one KDP let loose,it wasent pretty or cheap to fix.
