Stenny
Registered Member
Ok so I have done all the research so far on doing a cummins swap in my old Chevy truck so far besides the engine these are the parts you are gonna need to use a cummins and your bulletproof sm465. So here are the part numbers I haven't gotten any of these parts yet this is just what I found we would need I am still on the search but having the part numbers makes it much easier to find the parts.
Here are part numbers to do cummins swap and using the sm465 tranny which I believe uses the same adaptor and bellhousing as the nv4500
3910516 Transmission Adapter 289.96
3906803 Flywheel Reman/Used 400.00
3913056 Flywheel New 870.34
3934080 Spacer, Starter Motor 72.43
3906804 Cover, Flywheel Housing 276.11
Reman/Used
3916101 Cover, Flywheel Housing 648.34
New
Cover Flywheel Housing=Bell housing I think.
3964432NW Starter, Denso, 12V, 268.84
13T, 2.5KW
Reman/Used
New
13T, 2.5KW
