curious about tire size and lift,,,
AFUFO said:
Dont get adaptive lug nuts. Get hyperactive adaptive lug nuts.. they stay snug forever! They retail for about 3 bucks a nut at AutoPwn
Also remember if your going in the mud 10 bolt is the way to go..any other axle will lockup and melt the gears jamming it forever =(
IMHO 6" Lego lift 42' Irok bias is the way to go.. remember to use a hammer to beat the fenders in so you dont have any rubbing.
AlWAYS run in 1st gear! Hitting the rev limiter is the key to beating the trail!
man i'm glad i junked that 60 for the 10 bolt.WHEW!!
You have to keep your body lift = to 1/2 you block height. Just use one hocky puck for every inch of lift.
BTW, you need at least 6" of backspacing on you rims to fit 32's with no lift. Or just use some 2" wheel spacers.
just put non steer axles under there so all you can do is go straight then you wont have to worry about cuttin ur body up:haha: :haha: :haha:
draining all your oil and tranny fluid will take off some weight so the 4 inch will be more like 4 and 1/2, i hope this helps, it should still run fine:haha: :haha: :haha:
TexasBlazerBoy said:
What about the flux capacitor, I heard that adds a lot of poines:wink1:
It only works if you can get it up to 88 though!! I would reccomend some piston return springs!
