I did the 12V swap months ago using the Roscommon instructions. I have double- and triple-checked that it was exactly to plans.
First issue was that it wasn't charging. I finally figured out the exciter wire to the alternator wasn't showing 12 V when running. Rather than chasing wires I ran a wire to a key-on hot. Problem there was when I shut it off there was still enough residual voltage somehow that the truck would continue to run. Changed it to a key-on hot with a switch in the circuit. Start truck, flick on and off switch which excites alternator, charges fine. Mickey mouse but works for now.
After a month it started discharging batteries when parked. Hooked a test light between positive terminal and positive cable and pulled all fuses. Light stayed on. Unplugged the two wire plug on top of the alternator and light went off. So, the black wire is through an open switch and can't be the culprit and that only leaves the red wire. Checking voltage with truck off and key off it is showing .2 or .3 V at the red wire. Not a lot but enough to discharge the batteries in a day or two.
Any idea why any current would be present at the red wire with the key off?
