Custom Length Brake Lines
can I get a quote for brake lines for a 91 v3500 6" lift, d60 front and 14b rear. also has the load valve in rear. shipped to 99301 , in clear. thanks
$150 shipped.
ok, I'l measure my rear to see where that puts it. I gotta build all that yet and kinda wanna match my bling orange fronts I got from ya. What the price on the colored (orange) rear drop line? Does it have the T on it already?
$60 shipped and yes it has the T on it. Your existing lines will hook right up :)
twoslo4five0 said:
are you still selling theese if so i need a set for a 6 inch with a 3/4 ton 44..
Yes, we still have these. Do you need all 3 lines, or just the front 2?
Front only are $100 shipped anywhere in the lower 48.
Fronts & rear are $150 shipped anywhere in the lower 48.
just the two front i was running skyjacker and the banjo joint isnt big enough for the 44 i just put in...i was running a 10 bolt 8 lug and went to a 44 8 lug and the banjo joint needs to be bigger...do i need new lines or can i just change the joint...
Let me preface this with "I am not trying to make a sale". But, you do need new lines unless you have a way to remove the 10mm banjo fitting and install a new 7/16" one. Some hydraulic shops will do this for you, but you will lose at least 1-2" off the length of the line.
Not trying to push you one way or the other, just letting you know the facts. :)
can i get a quote for two front lines, 36" long, clear, top fitting 1997 k1500(ifs), bottom (10 bolt) 10mm banjo block
thanks drew
mini_mull said:
What happened to $40 per line? Is the special over or what?
I need to/will update the first post. The prices for materials have gone up since we first started. The average line is $50 shipped. In some cases where we are doing custom fittings, the cost is a little bit more due to the fact that the hardware costs more.
Can you set me up with brake lines? 1990 Blazer, 2 1/2 lift, 3/4 ton axles... how much shipped to 83815
I don't think Shane is in business anymore, his website doesn't work anyways. His last post was 9-20-07.
