Typically the levers you've seen actuate small master cylinders that apply each rear brake independently. If you have a selectable locker, you can just put it in "open" mode and lock one wheel to try to pivot on the locked corner. How well it works depends on weight transfer and terrain. With an auto-locker rear, you put it in front drive and then you can apply only one lever to lock one side with the other free-wheeling. And with welded, it's like an auto locker except that you can not lock only one side and let the other free-wheel. Many people find that this works just fine and may work better than single side in some terrain and orientations.
Some also use line-locks, but they don't have levers and are not as easy/fast to use since they require hard brake pedal, apply lock, release, do maneuver, apply brake, release.
Physical installation requires considerable re-plumbing to get separate lines to the rear brakes but is not terribly difficult.
Are you absolutely sure about this? It was my impression the lever still required you to push down the brake pedal first, then pull the lever to "hold" the fluid to the caliper.
If what you say is true, is there some sort of bypass required for regular braking? Elaborate on this a bit more and even a complete plumbing flow diagram would be helpful.
I'm going to order my CNC cutting brake kit and junk the Hurst Line Locks I currently have.
Good Topic guys! /forums/images/graemlins/peace.gif
