FlatBlackBurb
after a week and a half of my truck sitting in the driveway, i finally had it finished. the dana 60 was in, the 8'' lift springs were in, shocks, brake lines, and crossover were all completed. the steering works great.
i took my truck for a test drive today and experienced a really bad death wobble coming from the passenger side at any speed above 10mph. also my brakes suck but thats only because i need to bleed them and the resivoir was low.
upon getting home, i noticed a steel shim for the dana 60 sitting in my driveway. i forgot to put it on
is this that big of a deal and whats causing my death wobble? i've got shims on the bottom of my spring pack that are bolted on there so do i even need the extra one?
all ubolts are tight. it wobbles just coasting at 10mph, and braking at 10mph. i didnt dare try speeds above that because the wobble was intense. i only drove it probably a half mile before turning around and coming back home. i've got the same rim/tire combo on the d60 as i had on the 10 bolt. 36'' TSL super swampers. never had a wobble problem with them before.
also my brakes are leaking where i bolted the end to the caliper. also the brake lines that came off the d60 looked like the ones on the right of the picture. the ones i put on look like the ones on the left. does that matter
i bolted them down as hard as i could but theyre still leaking
