Only one I can find that every sells is for a JK. Yokon says it won't fit my 77 d44. I am thinking they are lazy and haven't bothered to check and just say no.
Any one know either way
www.yukongear.com
JK/ JL Dana 30 & JK Dana 44 Front Pinion Preload Solid Spacer & Shim K
Yukon Gear & Axle manufactures a full line of top-quality small parts to complete any job including ring gear bolts, crush sleeves, pinion nuts and washers, axle studs, thrust washers, and other general maintenance items. You can count on Yukon to fulfill all your differential small parts needs.
