D44 Passenger x-over knuckle
80 Chevy K20 4x4
Athena, OR
I bought this from fellow board member 82K10SBC, but I never used it.
Just the knuckle, no steering arm, no ball joints. Milled, drilled and tapped by a local shop. Fits Chevy Dana 44 axles with 6 bolt spindle. $85, buyer pays shipping - SOLD!
Also, I have a Dana 60 crossover draglink with ends that I bought off this forum, but never used it either - SOLD
Here are a couple pics. The knuckle needs two studs and the crossover draglink just needs new TRE boots, the joints are nice and tight.
Drag link was on a Dana 60 front axle I believe, I bought it from a fellow board member in this thread;
I will sell the drag link separate for $75 + shipping (that is what I paid for it, and I never used it because I sold the blazer it was going to be put on)
Knuckle for $85 + shipping (that is what I paid for it, and I never used it because I sold the blazer it was going to be put on)
Think it'll fit in a flat rate box? Let me know what it'd cost shipped to 95648 in CA.
Thanks,
Anthony
Edit: Forgot to ask what year/make/model it's off of. Just want to make sure it matches the bottom up taper on my 10 bolt and isn't an earlier GM or dodge knuckle with the top down taper.
Thanks,
Anthony
It's a Chevy Dana 44 flat top knuckle that I bought from this thread;
http://coloradok5.com/forums/showthread.php?t=303027
IIRC, Dana 44 was made up to 1976, then Chevy made the Corporate 10 bolt front axles. I'm pretty sure Dana 44 front knuckles will fit on a 10 bolt axle anyway.
GM still used the Dana 44’s mixed in with the 10 Bolts up in to the mid 80’s but I think only the early versions had the top down taper and there are also Dodge/Jeep Dana 44’s that will bolt right up and look almost identical except for the tie rod arm being higher up and having the wrong taper. That’s why I wanted to double check but as long as it came off a Chevy I think I’m good. I had some unexpected expenses pop up over the weekend that dipped in to the truck fund so I'm crossing my fingers the knuckle is still available when I get paid next week…
drill out 1 knuckle and use this http://www.wfoconcepts.com/pr/Tapered-Bushing-GM-Tierod/3163/3204/4086
make sure its the taper you need for your size rod end .
That's sweet! Thanks for link, WFO is actually about a half hour up the hill from me too. I keep meaning to drive up there to check them out and buy some stuff for the K5 but keep having to fix or replace stuff around the house…
