D60/14ff
Florida K5
Florida
in the process of building my D60 and I need to know what calipers to order? I am not sure what year truck the axel came out of and I want to make sure I order the right one>>
Second what rotors do I order for the 14? I was told they were just 3/4ton rotors just want to make sure this is correct before i order them.
Any mid 80's K30 should get your D60 parts, just specify SRW or DRW appropriately.
As for the rear rotors, 75 3/4 ton D44 will probably work but I'd double check with the disc bracket maker.
I always use 1985 k30 for my dana 60 parts.
For rar calipers, we need to know what brake lines you plan to use out back.. Around 1980 chevy went from a 3/8 banjo to 10mm banjo.
So if youre going with 10mm lines, which is what i would do because in a bind a IFS truck front line will work and i actually use those, then 1985 k20 front calipers.
