D60 brakes & lift Q
ace138
The colony
Do both D60 and 10 bolt caliber use 10 mm banjo bolts? I'm doing an axle swap and don't have the 60 at home (it's at the shop getting regeared). I need to know if the brake lines for the 10 bolt will work on the 60. If not, I will need to know what to buy.
Aso I need to know how much lift I will get running 2 1/2 lift springs on a stock D60 spring perch. My understanding is that I'll get a little more lift since the perch on the 60 is a little taller than the one on the 10bolt.
Thanks
yes on the banjo bolts and i think 1/2" taller
Banjo bolt size is the same. When i did my D60 swap i measured the difference in spring perch height and it was .750" difference.
I have an old 60 Not sure the year but it was neck down. The banjoe bolts are 7/16. I just drilled out the fittings from my 10 bolt hoses.
