D60 center jacking
76zimmer
Flyin Rat
Staff member
Moderator
Kzoo, Mi
I use a 2x6 flat on the jack with a 4x6 angle cut to clear the diff, and screwed to the 2x6....what do you use to jack your D60 up in the center?
A chunk of 6x6, it leans a little but not much and still gets the whole thing up to get stands under it.
Your block was sweet dave:waytogo: that thing was even stable when in the air. I bet kurt could make a cheap marketable cradle that plugs right into the swivle hole on the end of a floor jack:whistle:
I just slide my floor jack under the pumpkin and lift from there, so what if the truck leans slightly, just have to go a little higher before being able to get a stand under the driver side.
This.
Martin
