D60 DRW Machining
79k20350
3/4 ton status
Ct
What need to be done to machine drw d60 hubs to srw? ROughly how much does it cost? Thanks guys!
DRW = Dual Rear Wheel
SRW = Single Rear Wheel
He is wanting to convert the hubs of a dually to a single wheeled hub.
exactly, i know it can be done, im just not sure exactly what need to be done.
You need to machine off the wheel stud lugs that are closest to the lockout. Then you should make a plate that goes back on the other lugs. I believe these are usually welded on as well as wheel stud splines engaging in them.
In the end the lug nuts will hold it all together. The plate is mainly there to reinforce the lugs. Normally the plate is a part of the SRW hub.
