I'm trying to rebuild my D60 knuckles before I install it. So the axle is sitting up on jack stands. I'm at the part where I need to remove the kingpin, and eventually it will need to be re-installed. I'm reading about 600 ft-lbs being required for this. Surely I'm not the first person to work on this axle off the vehicle, and without a fancy axle clamping rig. Any suggestions on how to apply that much torque to a loose axle without just pulling it all around the garage?
Also, I'm looking at 7/8" allen sockets. This one looks good enough and not crazy priced:
https://www.4wdfactory.com/store/pr..."-Hex-Wrench-{47}-Socket,-Upper-King-Pin-Tool
But this one is dirt cheap:
http://www.amazon.com/Titan-15668-D...d=1377918280&sr=8-1&keywords=7/8+allen+socket
Anyone used the second one successfully? With an air gun?
