D60 limited slip options?
afroman006
College Station & Kingsville, Texas
I've been looking and I cant find any limited slips that I like for my D60. I'm fixing to replace the gears so I want to get a limited slip up front. I really want a Detroit Tru-track but I dont think they are made for D60's so what are my other options? I would prefer one with gears instead of clutches but I want to see what all my options are. Thx
depending on what kind of wheeling you do you might not want a locker, but if you do--lock-rite--
if you are set on a posi--the toughest ones i have seen are power-loc's
[ QUOTE ]
Where can I look at them? I do not want a locker b/c or steering issues and cost. Last time I checked a D60 detroit locker was like $600 and most LS's area around 3-400.
[/ QUOTE ]
Even with my Power Lock I had steering issues. It acts almost as bas as a Detroit. The only real way around it is a selectable locker like an ARB.
they make trutracs for 60s but you do not want that expensive open dif
im running an electrack. limited slip AMD locker. works well, and still steers offroad.
[ QUOTE ]
[/ QUOTE ]
I was reading something last night, a back issue of Petersons, they built one for thier "Army" truck. Said they used new clutches, and the 35 spline side gears from a Dana 70 , so they could run 35 spline ( and they also used 35 spline stubs, and Terra Low locking hubs ). They said it was hard to find in junkyards, either version. /forums/images/graemlins/k5.gif
Stubs have nothing to do with what carrier you run, there is a u joint between them and the inner shaft. /forums/images/graemlins/thumb.gif
