D60 raised steering arm and block w/studs for lift
garlicbreath
Denver
Dana 60 raised steering arm with block and studs for drivers knuckle.
75.00 or best offer.
Possible trades for tools, tool boxes, get creative, all I can do is say no right?
Not trying sound dickheadish but the subject title sounds a little misleading when you say "raised steering" arm when the pic clearly shows a stock arm. The block is the only thing raising this factory arm. I was assuming there was gonna be an actual aftermarket arm on there.
Just a heads up.
Well, I might be wrong, but the factory arms don't look like this on the bottom. It has a spacer built in to compensate for the block. But your right, the arm itself isn't lifted.
that spacer pops out and stays with the block and studs.
oru makes raised arms and thats what we were thinking it might be.
Yeah, that round spacer is part of the block/stud kit. All it does is raises the spring up so the knuckle has its pre-load on it.
Try installing that arm and round spacer without the block. You will never be able to do it. Gotta remove the round spacer to fit the arm in stock configuration.
OK then, it looks like I am selling a STOCK chevy dana 60 arm, with the block, studs, and spring spacer needed to raise a STOCK chevy dana 60 arm up 4 inches. Any takers now that we have that all cleared up? Price is negotiable.
