D60 steering block, slider windows, tailgate, etc...
6.2Blazer
3/4 ton status
Ohio
Fall cleaning sale to get the garage ready for winter. I have pictures but not downloaded yet:
1. Sold
2. Sold
3. Sold
4. D60 steering block (to correct for lift w/ stock style steering), sits between top of knuckle and stock steering arm, 3" tall. Machined out of a solid chunk of steel (not cast). No studs. - $20
5. 3" lift blocks (2.5" wide) with about 3-4 degree taper. - $10 *Pending*
6. Rear tailgate from '90 K5 Blazer. Good shape, factory trim panels, power window motor and regulator all intact , NO glass, hinges intact. Just needs on of the lift assist springs replaced. It's been years since I've used this but the the window motor still worked the last time. Stored inside since. $75
7. Factory front wheelwell trim from mid-80's Chevy truck (both sides). $10.
8. Sold
9. Sold
10. OEM slider windows from topper, dark factory tint. Wing window on driver's side fell off but I still have it. The little plastic inside latches need replaced. I ran trails with this topper for years so the windows were subject to brush rubbing against them....no major scratches but some slight scratches/rub marks you can see if looking at them close, never tried to rub them out. Includes factory rubber seals that seem to be in decent shape. $50. *Pending*
All items located in Marysville, OH (43040) - 20 min. from I-270 / Dublin area
