Wanted D60 Stock Steering Arm
toomany
Auburn, MI
Looking for a Dana 60 drivers side steering arm. Either stock or aftermarket.
Truck has 4" springs and axle I don't have plans for crossover at this time. My factory arm was torched off when they went to full hydro on this axle.
Dodge king pin 60, but I believe the GM ones are fit just the same.
I have a Dodge one, I will see if I can find it when I get home.
i think i have a gm arm .
the dodge arm will be to much for the 4" lift i tried it once .
made we can work a deal out between us 3 ?
Does the Dodge one curve up more than the GM one? I think I remember seeing something about that before.
@sweetk30 I may be interested in the Sniper parts you have as well. I'm down for whatever we can figure out.
gm arm = tapper top down low slung arm
dodge = tapper bottom up high slung arm
let me check my pile of 60 parts .
UMMM....... sorry I only have the dodge arm available, the Chevy arm is on one of my trucks. The pic was just for comparison.
I have a Dodge arm and sent it to Kert to weld and retaper the hole opposite to match the GM taper.
looked in my parts washer pile and all i found was a dana 60 block spacer setup for steering . sorry i am out .
I've got one. I'm going with an ORD crossover arm. I have the new arm but haven't removed the old one yet. Let me know if you still need it.
Sending you a message. We think the previous one is lost somewhere within the USPS system.
If @tonytheplumber has gotten rid of his already, then I'll hit you up for one of them.
Mine is still on the knuckle. I just received new studs yesterday which I ordered from WFO Concepts, so I can install the crossover arm onto the passenger side knuckle. I've got sort of a hectic week this week and don't know if I'll be able to spend any time in the garage, and I'm gone with wifey all weekend. Let me know whether or not you need it or if @sweetk30 will be sending one and I will be able to get it removed and shipped next week. You pay for shipping and the arm is yours
