85mudblazin
Anyone know where to get JUST the studs?? Every place I find that has them wont sell just the studs, you have to get the u-bolts to.
Thanks
-Chris
Thanks
-Chris
Neither, Fastenal doesnt carry anything like this either.Emmettology 101 said:
85mudblazin said:I think I am just going to re-drill and tap the holes to 3/4" and run some course B7 3/4" all thread for the studs.
jolane said:The studs I just got from ORD do not appear to be from ARP. Instead, they have a sybmol stamped into the ends, but I do not recognize it. I am at the point where I may not use my studs I just got. Haven't finalized the decision yet whether I want to use Zero rates or not. Unfortunately it appears that the studs only work with extremely thick spring packs or zero rates and regular spring packs. Not sure why they are set up this way...useless unless I go ZR's.
jolane said:Why not just use bolts? I am not sure what the advantage is of the studs. Seems Gr. 8 bolts would be more than good enough. The stock bolts are only Gr. 5.
