d60 vs d44 tie rod length
NorCal_Chris
Sacramento CA
Whats the difference, if any, in length on a d60 s a d44 tierod? Im wanting to use my d44 tierod x over setup on the 60 till i get an arm for reg crossover, and was hoping it would fit :confused:
damn.....
so i guess i will have to get a pittman arm puller. and re index my arm to front to back.
guessing stock d60 steering should work.... i have a cut down draglink for push pull already since i have 52's.
Plan is im going to get the 60 and swap my 44 at the same time to the other truck. So gotta get all my ducks in a row
I re-used my D44 drag link on my D60 and it fit just fine, no adjustment had to be made at all.
I used my 3/4 ton stuff as well. I had to take prolly an inch off each end of the tube and then thread the TRE's almost all the way in, but no problems.
