hey, sorry I didn't get to look at this thread.. promise I'll read it tonight when I get home and post up...![]()
Not a problem man! I know you're a busy man.
what gauge did you go with?
only thing I would say is if it's not thick thick, you may wanna consider adding a cross piece across each of those 4 section... I ran like 12 gauge and I still have a bit of "oilcan popping" every now and than in the larger open areas... it's due to being sheet, without the strength of the corrugation.. at some point I planned to go back in and add a couple underneath..
probably just get cr@p in it.... I would just modify the existing frame by adding the new stuff in the same right angle deal.. I would definitely make sure you tie it in to that frame at it's ends, whether straight across or the angles you posted....
if I was going straight across, I would just cut em like this
looks really good...
I hate to say it, but I would consider slamming a few more holes in for your welds... I would add a set 1/2 between...
