damaged Inner shafts? (Pic)
Zeitler
Sweden (Northen Europe)
I'm about to install new inner axle seals ..but
will these shafts ruin the new seals?
don't know where on the machined part the seal rides..?
The shiny spot.
clean em up. maybe polish them up a bit more so they are smooth and won't tear up the seal.
Lube up the seals with some oil or grease before you slide the axles in. ;)
other choices..
They may have "speedi-sleeves" available for those axles,they give a new smooth surface for the seals to ride on...also you can buy "Repair" wheel bearings that are offset a bit so they ride on the unworn area of the axle,and they are a sealed bearing that does not require the OEM axle seal...but for ultimate strength off road you may prefer to get a better set of axles that have no pits or wear.. :crazy:
