damn i just put 500 degree chassis gfrease in my spicers,,,
R72K5
Banned
central IL
did i screw up ? will i be able to push the disc brake wheel bearing grease out of the spicer u joints with multi purpose chassis grease and be fine ? these are joints that have been dry and sitting for years and this is the first grease put into them for a real LONG time,
one is not taking any, i dunno what the deal is, the ball valve in the zerk is fine, humm,..,
im afraid im gonna have to replace it,..
but the other three are fine so far,.
thanks
As long as the same type of grease is in the joint all the way through, and you keep them greased, you should be fine.
Unless you'll be running in the water a lot, pretty much any grease will work OK.
but i just pushed out black chassis grease by putting in the yellow hi temp disc bearing grease just now
will i be ok if i go get black chassis grease and push out that yellow grease ?
or is it too late now ?
thanks
Just pump in plenty of yellow, so no more black comes out. Once you drive it a few miles, pump in some more yellow to purge anything that was trapped in the needle bearings. Like I said, if you're not playing in the water a lot, the type of grease used in U-joints isn't as critical as some people make it out to be. Pump a couple squirts of fresh grease (always the same stuff; DON'T mix different greases) in the joints periodically and you'll be fine.
