DAMN IT RENE!!!!!!! **update**
Re: DAMN IT RENE!!!!!!!
if your pretty good with atorch thats the way to go Mike(blazen91)is becoming a pro on doing perch moves and always reuses the old ones.
88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
Thanks Brandon!
Brian
89KBlazer
Build it Right or Don't build it at all!!
I plan to make a set of perches like Glenn (depdog) did so reuse is not an issue! Maybe I'll just have fun with my new cutting torch!!!
Thanks Tracy
Brian
89KBlazer
I don't know about an Oxy-Acety torch, maybe a Plasma Cutter
The oxy-acety it a little hard to control (as in the flames will splash everywhere when it hits the perch and may be harder to see) and you might just torch through the housing if you're not careful. But I did use the oxy-acety to remove the shock mounts.
I have an air cutoff wheel that rotates at 24,000rpm. I didn't use that though, b/c I don't think my A/C is strong enough for that tool to reach max. So, I just used my 4.5" electric grinder. It spins 10,000rpm. And I bought a few cut off wheels for the grinder. It's exactly like the ones for the cutoff tool, except it's 4.5" size.
Boss
Pic of my truck Before N' After
<a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
The Blue universal wrench would make it REAL easy. Proably 5 minutes and both purches would be off without beating on them.
Well I may get to do this all over again this weekend. Swaping axles out to get my 4.11 and detroit!!!! YEeee Haaaa! I'm a little low in the rear so I'm going to slap a set of 2 inch blocks with a 4deg wedge in them and see how that works. If I don't like it I'll have to cut and reweld the purches to get my angle right.
Dollar will finnaly Be big very soon. Will be Depdog size. Damn little 32's are about to be off once and for all.
Anybody want to buy a set of well broke in BFG MT 32's? Between 60-80% tread left on them depending on what tire (a couple have had bad encounters with and they lost and had to be replaced) except where I have ripped a few lugs off
It's not my damn planet monkey boy!
<a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
75 Jimmy, Dollar
79 Chevy Blazer, Her's
70 Chevy Burb
Grim-Reaper
The blue universal wrench
What is and what should never be....
<a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
I'd use an Arc-air gouger and have em off clean in a few minutes each...but you need a damn big welding machine for that.
The hot wrench is another option but its easy to gouge into the axle tube when removing the perches...which would be bad...
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
Tell you what.. Wes did all the prep work on mine before I picked them up..
thatk30guy rocks !!!! he even moved my shock mount's high up on the axle tube's..
Bolted right in.. no alignment problems... dead on the mark.
Thanks a bunch Wes..
I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
ttt
tRustyk5 for President!!!
