88trailblazer
I installed a used Rough Country 6 inch lift from a k5 on my k10 recently. The front was sitting slightly lower than the rear and my 38.5x14.50 TSL/SXs were rubbing. I installed a set of EZ-Inch blocks up front with 4* shims (because the springs were missing the original front shims). I also moved the axle foward 1 inch. I still have death wobble. It was there before the EZ Inch and shims were installed. It happens around 20mph and when i start to brake.
Does any one know how many degrees i would need to shim the front to get the correct castor? I installed a set of aluminum shims just cuz i had them laying around but before i spend money on steel shims, i want to be sure that they will work. How can i check the castor on a front D44.
I'm also running crossover with no steering stabalizer. I know that the stabalizer will help cover the problem but i want to get this fixed before i add one. I'm also going to change out the front tires with a set of 35's tomorrow to see if that helps.
I'll get some pics up soon.
