I sometimes park the K5 outside under my carport if I'm cleaning the garage or have a project going on. I had left it out for a few days without starting it, and when I went out the other day it was stone dead. Figuring I had left something on by mistake, I hooked up the jump box only to have it spark violently. A couple checks with the voltmeter confirmed I had a hot wire that was grounding somewhere. Following the main positive cable, I found it missing about an inch of insulation, and welded to the side of one of the header runners. The culprit lay dead underneath the truck. A cable repair and a new battery later and I was good to go. Poor critter, 1000 amps couldn't have felt too good through his teeth as he was gnawing the wire. I guess I should be lucky the damage wasn't worse than it was.
Moral of the story--park your cars inside or start them regularly to prevent vermin from taking up residence.
one of the most painful shocks ive had was sitting in a non AC'd 72 regular cab chevy on a 100+ degree day and bracing my hand on the dash trying to cut a wire shorting out under the dash..... I've been an industrial electrician for 17 years and have gotten into a few things.... that shock in the truck SUCKED way worse.... if a squirrel chewing a wire got his head between the wire and header it would have had an A$$ load of amps right through his tiny skull
that'd hurt
..I am glad I have at least 3 feral cats keeping watch now...I found a dead mouse by my front steps this afternoon..good kitties!..
and 1 amp across your chest (hand to hand, hand to other foot, etc.) will kill you.
