Dana 44 Big Hub Question
Hannibal
BC Canada
All
I have a 1974 Dana 44 "Big Hub" 8 lug axle. I rebuilt the hubs, but I can't seem to find the torque specification for the (6) 3/8-16 course bolts that bolt the locking hub to the rotor. And, would you recommend using some "blue" loctite to make sure the bolts don't get loose.
thanks in advance.
I may have a manual with the tq spec, I'll go check. I'd definitely use some blue Loctite as I recall it's common for those bolts to loosen up.
BRB
30-35 lbs ft per Spicer manual.
Be sure the bolts have washers, they use a specific thick washer with a small outer diameter to fit the bolt pocket.
I'm uploading the manual to my albums now if you need any other info.
You sir, are awesome.
I have the washers, and all the parts look good. I ordered new rubber seals and gaskets to do it right. Thanks for the help.
