blazinzuk said:sure looks like it. I sold some to a guy for 50 bucks. Of course I made him take the rest of the axle too.![]()
you got screwed. I have never gotten less then $100 for the knuckles. if it's 8 lug you can sell the hubs, spindles, and backing plates for another $100. the shafts someone will give you $20 for. if its 4.10 or 4.56 gears someone will buy them for $50 or more. I have sold stock open carriers for 4.10 and lower for $40.All flat tops have the tie rod on the bottom.JDNobodi said:First set of flat tops I’ve seen where the tie-rod is on the bottom. With the solid backing plates, I think this axle is a transition year, about 1976 or 1977.
thatK30guy said:All flat tops have the tie rod on the bottom.
And yes, the solid round backing plates began in '77 which was dubbed the "second design" axles for GM. This also marked the beginning of the 10 bolt front axles, too.
Go take a pic of yours. Is the tie rod upside down or not? I'm betting you either have knuckles swapped in to your front or the whole front axle is a newer design.JDNobodi said:(Gets Up, put on slippers, walk outside, look under the 74, and look at non flat top 44 in back yard)
You're sure about this?
Thats one of the differences. There are more. Tubing size is another. Calipers are one more.pauly383 said:I thought the main thing was the spindle size . Larger inner diameter inner bearing on the "new" design .
pauly383 said:Looks like the tie rod is loose in the knuckle on the drivers side , the castle nut is cocked to one side . I'd make sure the hole isn't wallowed out .
thatK30guy said:Go take a pic of yours. Is the tie rod upside down or not? I'm betting you either have knuckles swapped in to your front or the whole front axle is a newer design.
Get some pics up......
