Stomis
Professional Amateur
Alright I'm starting a new post because my old one was a little to specific. I'm on the fence whether or not i should rebuild the new front dana44 I just got for my truck. Its a fulltime axle and i have the manual hubs to convert it so I'm past that part.
I know I'm at least going to regrease everything but I'm wondering whats worth replacing. I was told it came out of a daily driving truck with a tight front end. I got the axle home and realised that the rotor on one side floats in and out a little bit. I know at this point I need to open everything up and retorque it down to spec so everything is snug.
-What should I do to check bearing wear? How can i check balljoint wear?
-Should I replace the balljoints? Do I need to pull the knuckles to replace the balljoints?
The axle does appear to be in good shape and seems like it was rebuilt at one point because it does have machine shop grease pencil tags and marks all over it and a fresh coat of paint.
