i4786
Registered Member
What are the pro and cons of running the 3.42 ratio?
dana-spicer part # 700025-3
I am running 3:42's in my 10 bolt, with SM465 and 35 inch tires. It's not too bad, but on the edge. With an automatic it would probably be worse.
Your saving grace is that granny first gear and no OD. An automatic, even a 700 which has a better first gear than a 350 or 400, would definitely be worse off.
