Dana 44 swap on 84 K5 Question?
rdohara
Apple Valley
Just put a Front Dana 44 (complete rotor to rotor with calipers) from a 77 K5 on my 84 K5 Blazer got it all on and when to put the brake line on the calipers and it uses larger banjo bolt on the Dana 44 then the GM 10 bolt What is the best fix for this?
I think you can use the calipers from the 10 bolt so just use those. But, you may want to wait for a more experienced CK5er chime in.
the castings are a little different had to grind off a small part of the 10 bolt caliper and it worked on the Dana 44 just fine
