dana 60 35 spline stub shaft question
sweetk30
Back to play nice .
in the back of your brain
what are you running for snap ring on the stub to the hub ?
i have a set of yukons and spicers getting broched to 35 spline.
need 2 snap rings what size and were to get would be super. thanks guys .
You can get a decent selection of clips at Ace hardware if your hubs allow room for the full circle clip style. The Warn hubs come with a full circle clip, but the clip can get pretty close to the back of the hubs if you use spicer stub shafts. Evidentally, the Yukon shafts don't have that issue.
Don't know the size offhand, but you can measure the stub shaft diameter and get a ring slightly smaller than that.
