dana 60 and 10 bolt help
Redneckmudslinger
Registered Member
Maryland
ok i have a 88 gmc jimmy sierra classic i want to beef up my rear end and get rid of that 10 bolt that i have now so if i swap the rear with a dana 60 and put 4.10 gears in it and i keep the 10 bolt in the front and put 4.10 gears in that would that work ok im not planning on doing extreme off roading i just like to beef rear up so i dont blow rear when doing burn outs etc... so would that work if then both had same gears just rear being dana 60 and 10 bolt front thanks
Yes it'll work.
That said...
Are you trying to keep the same lug pattern? Most rear axle upgrades will be 8 lug. If you want to stay 6 lug then you might consider a semi floater 14 bolt swap, it's bigger than what you've got and available 6 lug (although a little hard to find).
The easiest / cheapest swap will be a full floater 14 bolt, one from a 3/4 to is almost a direct bolt in.
it would be nice to keep it to a 6 lug but if i get a 14 bolt is there some way u could convert it to a 6 lug do then have kits to do that ?
The full-floater is 8-lug only. There are some fancy hubs to convert to six lugs, but they can cost more than the whole axle.
The 14 semi-floater came in 6 and 8 lug. As said, the 6 lugs are a little rarer and more desireable.
whats the difference between ff to sf when it comes to 14 bolt rear
Smaller ring gear, no 3rd pinion bearing and semi float only. However, it's way better than a 10 bolt. They are also the same width as the front axle which is a plus. It will be plenty for what you want to do.
The full-floater is about as bullet-proof as it gets until you go to rockwells. We mainly do this swap because the axles are fairly plentiful, cheap, and easy to swap.
It all depends on what you can find, what your budget is, and what you're willing to deal with.
I got an 8 lug semi-floater and a matching front from a 3/4 ton truck. Since I was getting larger tires anyway, and got the axles for such a good deal, it was an easy choice to just get new wheels and bolt everything in. Semi-floaters are plenty strong enough for all but the largest tires. If you have a 6 lug front, you can readily find 8 lug hubs to make everything match, as the corporate 10 bolt front axles are the same.
Semi-floater 6 lug axles are desirable, but will almost certainly be more expensive, and depending on which one you get, may require relocation of spring perches. They will be from newer trucks and vans, so you have to pay attention to axle width as well.
Full floaters are tough, readily available and inexpensive, but pretty much mean you're going with 8 lug. Parts for them are cheap. The main disadvantages are that they are very heavy, and if you aren't running big tires ground clearance with that massive differential can be an issue. However, that's an axle you'll never need to worry about unless you're going monster truck big.
I've seen a lot of people that for some reason have an aversion to 8 lug axles, either because they don't want to change wheels or front hubs, but IMO it is usually a much simpler and more economical route. Unless you've got thousands tied up in your wheels, I guess.
Some 15" wheels won't clear the big 14 bolt drums.
Also don't forget ground clearance, a full floating 14 bolt hangs low. This could be an issue with 35's.
If you don't plan on doing extreme wheeling and want something cheap, I would suggest a set of 8 lug 3/4 ton axles out of a Chevy truck with the 14 bolt Semi-Floater. That will give you a stronger rear axle, larger front brakes, better gear ratio (4.10 is commonly available if you look for them), and decent ground clearance. I have yet to hear of someone destroying a 14SF on here that only does light wheeling.
If you plan on extreme wheeling, go with a 14FF and Dana 60 front out of a 1 ton.
in the process of doing the same thing...
like the title says, I'm in the process of doing the same thing. I've got an '86 K5 and I've acquired a '79 Ford Dana 60 rear basically for free. It already has 4.10 gears and is in really nice shape overall. It was missing the brakes so I've replaced them with OEM type drums.
I couldn't afford a new front axle so, with the help of the same friend that gave me the D60 rear, I have acquired 8-lug D44 hubs, etc. that will convert the original 10-bolt front axle to 8-lug. Also picked up a nice set of used 4.10 gears for the 10-bolt front.
I have front springs and rear shackles that will give me about 4" of lift which should clear 35's.
Of course, all of this has yet to be installed. It's just parts sitting in my buddies shop still. :rolleyes:
