reddog64
OK,
So i'm getting everything i need in order to swap in a dana 60 into the 78 K5, had a dana 44 in it.
I want to do crossover with Hydro assist shortly after the swap...
I hava a donor 1-ton right now i'm stripping parts off, but it will be hauled away shortly, so i need to make sure i get everythign i can while i have it.
- I plan on ordering the ORD (or other vendor) arms and links i need for the crossover.
- I'm gonna order the ram and hoses needed from a vendor.
- I'm gonna order the diff guard with ram mount from DIY4x
- I need a 2wd steering box from a 73-87 truck correct? And i can tap it...
- I need to grab the brake lines off the 1-ton (dana 60) as they will bolt to my hard lines in my K5.
- I need to grab the draglink from the 1-ton to hook my steering up as stock for now till the crossover is done.
- grab the u-bolts and plates as the 44 ones wont work...
Can i run the crossover without the hydro assist for a while (no wheeling) and leave the steering box tapped, but plugged off? or just not tap it...
Has anyone made their own crossover setup.. just buying the steering arms...
