DPI
Are the dual rear wheel and single rear wheel front dana 60 rotors the same?
And can the rotor be turned without the hub attached?
What the others said. One has smaller holes and the other bigger.Is there an easy way to tell them apart?
yes, but when you press the studs back in and mount it to the hub, it tends to distort it a bit, which in turn could give you a pedal vibration.Why would the rotor have to be mounted? I would think it's more a question of what "accessories" the owner of the lathe has? If the shop / person has a big enough cone & cup it should center up fine. Wouldn't it be the same principal as turning a rotor for a late model truck with unitized bearings and slip off rotors?
I didn't do any research on it, but I had the rotors on my front 60 turned by themselves (not attached to the hubs) and have never had any pulsation issues...and it was done by a buddy who was a long-time GM dealership mechanic. Not saying it's wrong or right, but my experiences.
I guess I also don't understand how the rotors being lug centric vs. hub centric makes a difference in this situation.
I have adapters to machine semi truck brake drums if that tells you anything. Oh, i can also machine the drum with the tire/wheel still attached if need be.
Also, if someone is machining a drum or rotor and does not clean the mating surface then there is no way possible to have it machined true. A small spec of dirt/rust or whatever at the mounting face of the drum/rotor equates to a bunch of runout by the time you reach the edge of the drum/rotor. Just for this purpose when i machine used drums/rotors i bead blast the mating surface so there is no dirt/rust or whatever to contend with that would make the drum/rotor have any runout once machined.
Wish you were closer. Most of the places around here have inexperienced kids running the machines.
