rompinstompinmudmonkey
For those of you that aren't familiar with my towrig its an 89 CC dually with a 12 valve Cummins swapped in and rollin on 37's.
I want to improve the braking system but not sure where to start. I know the heavier wheels and tires play a factor, but I want to end up with brake performance that's similar to a new truck
The brakes work great when I'm not towing a trailer. I can lock up all 6 37's during a panic stop if I want to. I would consider the pedal a little low though. I've bled the brakes multiple times and even removed the master cylinder and bench bled it. I am 100% sure there is no air in the system. Under normal operation I'd say the pedal is 1/2 to 2/3rd of the way down to achieve a substantial amount of braking.
Is the master cylinder bad? If i change I'd like to upgrade. Will the master cylinder off a 2001- up 2500HD swap on and is the bore larger on the newer master than the old one?
Are there any caliper upgrades for the dana 60? I've heard of someone installing calipers from a 2500HD but have never seen pics or really found any info on it.
I plan on ditching the drums in the rear but haven't yet because I don't want to lose the parking brake. I'll probably just swap the whole rear axle for an AAM out of a GM or Dodge
Anyway, what's everybody's thoughts? The truck tows as good as a new truck. Time to make it stop like one
