Everything is sold
(Will work with less lift, I used it with 6" lift. You can leave the block out if needed too.)
ORD crossover steering for Chevy D60 w/ 10"lift... ($554.00 new) $375.00obo
Includes:
PS steering arm
Drag link and ends
Steering arm lift block
Extended Arp studs, cone washers, and nuts
Drop pitman arm
Cut off DS stock steering arm cap
Hydro assist includes ($500.00+ if all bought new) $325.00
Ram, hoses, clamp, and diff cover, SOLD and shipped
PSC 1.75" x 8" ram
3ft+ hoses
2wd box w/ tapped top cap and billet/tapped end cap. Mounting ears on box are not stripped, but the threads are worn enough that you should use longer bolts with nut on back side for added security.
DIY4X Razorback diff cover w/ ram mount option, 1 fin modified for more tie rod clearance
1.5 tierod clamp two clamping bolts are broken off (tierod not included)
Power steering pump and hoses from pump to box not included. Picture is to show fitting type for the box
Missing a few zirk fittings and a couple cotter pins. Drag link ends are tight with little to no play. Was not leaking when removed last week of July.
Shipping possible on your dime.
Includes:
PS steering arm
Drag link and ends
Drop pitman arm
PSC 1.75" x 8" ram
3ft+ hoses
