Sold Dana 60 crossover/hydro assist
ChrisPerry
Contemplating links
Ventura Ca
Everything is sold
(Will work with less lift, I used it with 6" lift. You can leave the block out if needed too.)
ORD crossover steering for Chevy D60 w/ 10"lift... ($554.00 new) $375.00obo
Includes:
PS steering arm
Drag link and ends
Steering arm lift block
Extended Arp studs, cone washers, and nuts
Drop pitman arm
Cut off DS stock steering arm cap
Hydro assist includes ($500.00+ if all bought new) $325.00
Ram, hoses, clamp, and diff cover, SOLD and shipped
PSC 1.75" x 8" ram
3ft+ hoses
2wd box w/ tapped top cap and billet/tapped end cap. Mounting ears on box are not stripped, but the threads are worn enough that you should use longer bolts with nut on back side for added security.
DIY4X Razorback diff cover w/ ram mount option, 1 fin modified for more tie rod clearance
1.5 tierod clamp two clamping bolts are broken off (tierod not included)
20160805_214323_zpsexi0sdgr_edit_1470466580078.jpg 20160805_215153.jpg 20160805_215106.jpg 20160805_214602.jpg 20160805_214532.jpg 20160805_214522.jpg 20160805_214208.jpg 20160805_220654.jpg
Power steering pump and hoses from pump to box not included. Picture is to show fitting type for the box
Missing a few zirk fittings and a couple cotter pins. Drag link ends are tight with little to no play. Was not leaking when removed last week of July.
Shipping possible on your dime.
Bump, lower price. Will separate a bit and offering possible shipping.
Will also be driving from Los Angeles to Moab shortly and can deliver along the way :D
Interested in the hydro assist portion minus the 2wd box(cover, clamp, hoses, ram). Can you pm me a price?
BTracy PM'ed me an offer on the hydro stuff about 2pm. If it falls through for some reason you'll be next in line.
I sent the money this morning.
Will ship out tomorrow. I'll PM you the tracking number at that time.
