Dana 60 F/R axles
Really? Had no idea is was worth that. So i should keep looking for a 14 bolt? If Im waiting which one? The FF or SF
Generally, used SRW D60's go for $1000 (Chevy, Dodge) - $1700 (Ford, high pinion) around here. Ford 60's are worth the most (high pinion fronts are good), then Chevy's, then Dodge.
DRW axles are a few hundred less.
Again, make sure that you are getting a front 60. The D44 front in that truck is probably worth $50.
And as for the rear, the FF 14 bolt will be practically unbreakable up to at least 44" tires. A FF 14 bolt from a 3/4 ton truck will be a direct replacement.
So what about bolting it to a 1/2 ton? I have a neighbor that has an old ford that hasnt moved in a year at least what should I offer for the front axle on that? Its an F250 with 8 lugs
An F250 won't have a D60, it probably won't even have a solid axle (most Fords are TTB).
Dodge D60's are pretty close to Chevy 60's, search on here and you'll find a ton of posts describing what it takes to make one work.
