dana 60 help on gear setup ( UPDATE Post 40 pattern check )
The pattern looks a little light. I would put some more drag on it to get a cleaner pattern.
Also, great upgrade with the power lock
Well. It looks a little deep, but I would probably run it. I'm having a hard time seeing the pic because I dropped my phone face down into a puddle of atf the other day, so there are 2 cracks in the screen, so its kinda hard to tell. How is your backlash? Close to spec?
Also, since those are Dana gears, they set up and run super quiet even if the pattern is a little off. Other gears I have installed seem to want a perfect patrn to run quiet.
6tho b/l with in spec.
i might play with the pattern a tiny bit more and see what i get . but i was thinking it looked good for the most part.
