Dana 60 Razorback. Finished units PICS!!
cybrfire
1 ton status
Iowa
OK, sorry for making you guys wait a bit but wanted to get a good picture of a production unit or two. The prototype has gotten hashed over and rehashed just a few too many times.
Front with tie rod clearance on the left.
Rear or histeer on the right.
All grade 8 hardware included. Locking flange bolts.:D
Nice 'n' beefy. BTW, love my 14B razor, Thanks Kert. Guess I'll have to buy the D60 cover, then I'll have no choice but to get the axle to go with it. :D
Couple questions. First, why does the middle fin not go all the way to the top? Second, will it clear a fat tie-rod in stock location? Third, any chance of a drain plug being offered? (Yes I am perfectly capable of installing one myself but if it came with one that would be tits).
The middle "Razor" stops for tie rod clearance. As to the size of tie rod it will clear in factory location is still being efforted. As to the drain plug, In my Honest opinion, they are a bad idea. Not trying to tell you what you want or need, however, If your draining the fluid, its either because its dirty or has gotten moisture in it. In which case, it'd be a good time to inspect those expensive gears, lockers, and so on.
specs are the same as 14BFF but the price is higher by 10 bucks. 110 plus shipping.
sounds good how long until they will be ready with the ram mount? ill keep in touch i sent ya an e-mail with a big list a few weeks back
I just need to do a little more checking on tie rod clearance and come up with an exact number as to how large a tie rod will clear. Otherwise they are ready to go. My factory tie rod has a big kink in it so I'm gona have to address that first.
your going to make some with a ram mount? or at least have an option for that?
Ready to produce
OK, these are all finished in the R and D phase and we're ready to start some production units.
Price is $110.00 plus the ride. Since the last pictures we have switched to a brass hex key fill plug. We also put the rest of the center razor back on just for the sake of being thorough.
They will be available with a Ram mount option but due to the different ends available on Hydraulic rams you will need to email us to set that up. Need specs on the pin size, clevis mount or tab mount and the like. The ram mount itself will be on the cover, not a piece hanging off the side. Also if a Ram mount is requested the fill port will be moved to the opposite side of the cover to make space. Ram mounts will be a $20.00 option.
If you need a rear cover and don't require tie rod clearance just let me know.
All of this will be updated to the website as soon as possible. Need some better photos that what I have now.
